John Deere D
I own a 1963 930 Case....Model 940 Gasoline Engine...6 speed
I've drained all OILS and am now on the last Compartment....Transmission OIL LEVEL PLUG....?
As per pictures...# 6 could someone verify if the location of the PIPE PLUG is indeed the Transmission OIL LEVEL PLUG....?
I could keep adding oil to verify if OIL is present at location as per Pictures.
Also, 930 Tractor Operators manual indicates 15 gallons of oil in the Transmission Case. Any difference between the 8 speed Transmission and the 6 speed Transmission as per quantity of oil..?
I also have an I/T Manual C-202
ALSO
There's a GEAR COVER on the LEFT side of the Transmission housing.
There's a DRAIN PLUG on the bottom of the cover on the forward end, as well as a PLUG on the TOP of the cover at the REAR of the Cover.
It would appear, I should drain the cover, then add oil....???? with the excess oil draining into the Transmission case.??
Thanks
Bob..
ALSO
Thanks
Bob..
