David Brown 3800
cam.crogie
New User
I have a David Brown 3800 that up to this year has given me no problems. This year we have replaced the hydraulic pump and now the mechanic tells me that i need a draft control valve as mine is damaged. Does anyone know where i can get one or what other David Brown models will fit. I believe someone told me the 770 or 780 were similar. Any information would be appreciated. This is my go to tractor for feeding round bales in winter.
Thank You
All the 3 position selectamatic valves are the same.
Unless it was deeply pitted from sitting for years with water in it, I have never seen one that couldn't be repaired by basic removal and cleaning and freeing up the valves. I have heard rumor of one of the sleeves coming loose and requiring a dose of loctite, but not experienced it myself.
If your 3 point was recently working, your valve is probably better than any you will find for sale.
