LA waterpump
FixinOldIron
New User
I'm putting my LA back together. Had the waterpump off but not apart. When I put the pump back on and the pulley back on the shaft I have about 3/8" I can push in against the spring. Is that normal? I know the impeller creates thrust to help seal. Is that what I'm seeing or is something loose inside the pump? Thx
I use to rebuild those for folks.
Grease it good and it should be fine.
Been a long time since I did one.
I think I still have one in my shop.
Will check tomorrow.
