Hello I bought this 22 with engine issues ( O rings on the sleeves leaking because silicone had been used when installed ,with very low hours on the overhaul it still had the hone marks in the cylinders ) ( why would they overhaul the engine with trans issues ) any way I got it running and drove it around power shift works as it should , I have 1,2 & 3 but when I shift to 4 th it just lightly grinds, I disconnected the shift cable from the shift lever it was a little out of adjustment , I put a vise grip on the shift lever, moved the lever both ways good detent , set cable , still no 4th ( I did pull back on the lever and it did move the tractor a little ways then it slipped ) . My ?? is is there any internal adjusting that can be done through the side cover or will this be a complete tear down to replace the shift collar ,or could the inner shift lever be wore?? Thanks Bryan
