crankin12864
New User
This message is a reply to an archived post by mEl on January 02, 2009 at 06:38:33.
The original subject was Re: Adjusting the 930 DOM valve.
My Case 930 3 pt is stuck in the down position. The 3pt Lever will not move. I relieved the pressure at the Hydraulic remotes hoping it would help to fix the problem, but it did not help at all. Some people said that the Draft-o-matic is probably out of adjustment and is causing the problem. What are your thoughts?
