Company Logo (800) 853-2651 Shop Now
David Brown 885 diesel fuel in crankcase
Jim in Sask
09-14-2021 20:06:45
I seem to be getting fuel in the crankcase on my 885. It brings the oil level up on the dipstick and occasionally the tractor will sound like it's laboring and smokes black out of the exhaust, even when not working hard. Most of the time it runs fine. There's no change in the antifreeze level in the rad and no sign of white "milk" on the dipstick. First thought is maybe an injector going bad - any other suggestions? Thanks for any replies.
Jim in Sask
09-15-2021 19:44:51
 Re: David Brown 885 diesel fuel in crankcase in reply to Jim in Sask, 09-14-2021 20:06:45
Thanks for the suggestions - they give me a good starting point. I want to get after fixing it as soon as I wrap up harvest.
RGMartin
09-15-2021 04:38:33
Could be the lift pump or the injector pump front seal.
The lift pump is much cheaper to try first.
I have been having many DPA pump front seals start leaking lately.
Jim in Sask
09-14-2021 20:58:00
Yes if you mean the one with a lever to pump fuel when bleeding the fuel system. I replaced it a few years ago when the old one started leaking externally. I didn't think of that in this situation - thanks.
J Hamilton
09-14-2021 20:27:38
Does it have a fuel pump mounted on the engine block? If so thats probably where its coming from.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: one 12.4X32 radial tractor tire on a john Deere 8 bolt rim. has some liquid within. Need to move its in my way as I do not have a JD to use such. Make me a good offer, and its yours. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
