1956 Case 403, I've used this tractor for several years with my mower conditioner. Last time out the hydraulics quit working. Plenty
of fluid. The eagle hitch goes up and down as it should, but the remotes won't work. The hoses surge a bit and it feels like its
maybe trying to work but no go. I've swapped out the hoses and the ends to eliminate that as a source of the problem. It appears its
in the pump controls, check balls, or whatever is behind the plate and inside the body. I have a cut away view of all the parts and
pieces of the control unit. But not sure how or where to start. If you can help I'd sure appreciate it. thanks gobble
