I have a 1961 Case 530CK with the Bendix single power steering cylinder in front of the axle .Can someone with a working tractor verify the correct location of the power steering hoses, they are all the same size fittings so can be installed wrong. I have the remote reservoir with the connection block under it, the front reservoir hose goes to the upper fitting on the pump, the back reservoir hose goes to the right fitting on the cylinder, the left (wheel side )fitting on the cylinder goes to the lower fitting on the pump. Are these locations right ? I tried swapping the hoses on the cylinder side to side but it still does not work? The pump seems to be working, when I started the engine with the reservoir top removed a fountain of oil sprayed up. I replaced the cylinder spool O-ring seals and the cylinder ram looks to be a replacement, it is a brown primer color. the spool nut pin was broken, I replaced with a section of 1/8 drill bit as recommended and screwed in all the way in and backed out about half a turn ? Thanks for your help
This post was edited by meijnew on 06/08/2021 at 08:53 am.
