So I got this not too long ago.I changed the shuttle fluid and it seemed to have better pushing power. Enough that I broke the poorly welded loader tower. I have fixed that now.
I used it for 3 hours today and noticed that sometimes when I release the clutch pedal the trans has good power instantly. Other times it takes maybe a second and then you can feel like something engages and it has power. The direct drive works well once it is moving.
Converter gauges do not work on this
I checked the fluid level while running on the level after it was warmed up and if anything the fluid was a little high.
A few times today I had to use low range just to be able to back up as the high range didn't have any power in reverse. Low range holds fine in reverse but likes to pop out in forward.
Any tips on what I should do to fix this?
TIA
TIA
