400 diesel
barnfull
03-30-2021 13:48:28
Is the 400 narrow front diesel different than the 400 super diesel?
What would be the difference in the two?
BarryfromIA
03-31-2021 13:19:53
 Re: 400 diesel in reply to barnfull, 03-30-2021 13:48:28
The manifold may interchange or not but it would be a conversation piece at a show where the Experts congregate or the Case version of the Super HTA which is really a 300.
comfortking
04-02-2021 19:44:47
 Re: 400 diesel in reply to BarryfromIA, 03-31-2021 13:19:53
We have a 400 Diesel COM tractor and a 400 gas COM tractor. The gas is a very early 800 s with the clutch pedal the looks like a clutch pedal and not the slab used on the later 800s. The diesel is a 400 which we changed the torque tube from a clutch to the Com The only have the foot throttle on the right side and I think they both are embossed with the word THROTTLE. We changed the manifolds and the front tubs as they are different. 800 tub is 3/4 inch longer in the rear, it almost looks like some of them have a spacer in there instead of being in the cast.
Roger Link
03-31-2021 06:26:28
I have a nice 400 Super Diesel that I would sell,It has nice 16.9-38 tires,narrow front,power steering works great,3 point with 3rd link and bracket,belt pulley,front wrap around weights,good fenders,was painted about 15 years ago and engine overhauled at that time,it starts right up on cool days,715-308-2163,Roger
chuck machinist
03-31-2021 15:20:55
 Re: 400 diesel in reply to Roger Link, 03-31-2021 06:26:28
Could I get some pics, my email is open. Does she have fenders? CM
Roger Link
04-01-2021 05:20:02
 Re: 400 diesel in reply to chuck machinist, 03-31-2021 15:20:55
Yes it has fenders and they are in good shape,I'll try and get some pictures in the next few days
BarryfromIA
03-30-2021 20:10:00
So could a person take an 800 and change the tin to 400 tin and style and call it a 400 super series 1 or prototype 800? It would be some thing to show around.
Don Rudolph
03-31-2021 06:42:14
 Re: 400 diesel in reply to BarryfromIA, 03-30-2021 20:10:00
You probably could, but the heads and exhaust manifold are different on a 400 SD than an 800. A 400 manifold has the muffler alongside the hood, an 800 has the muffler going through the hood. A PO put an 800 engine in my 400 SD, that's how I know. Don
Don Rudolph
03-30-2021 18:10:17
The 400 diesel didn't quite make 50 hp @ the Nebraska test. The gas version did. The diesel bore was changed from 4 to 4 1/8 and the RPM's increased 100 or 150. The tool box was made bigger and the CASE stamping on the lid omitted. Also, the steering column has a cast boss where the Case-o-Matic lever would later be bolted on with the 800 intro. Don
Roger Roemen
03-30-2021 17:21:04
Quoting Removed, click Modern View to seeOther differences include stub on steering column for the future COM, PTO brake, upper support for a cultivator.
2090
03-30-2021 14:57:03
Block A1111, thus bore & rpm
