Case 430 hydraulics
JBobbe
I have an early model 430 Case. Just a straight 4 speed. There are two caps for hydraulics as in the picture attached. One on the left and the other in line with the truck tire in the background. The only manual I've had someone look up says the capacity for hydraulic oil is either 15 quarts or 24 quarts. Is the reservoir just one or two separate ones? And what is the capacity of each if so? Thank you
Photo upload. Second try.
I was not aware that 430's ever used full fenders. I thought they were all clam shell. The front sheet metal looks 100 series(300)? Probably would be the same oil capacity though.
The small breather and plug is the fill hole and the large one is the normal breather. The cover they are in is the cover for the pump and optional triple range or shuttle. The manual for my 300b calls out 12 quarts, you should get a manual specific to your model.
When I had the clutch replaced, the parts numbers matched a 430. The gauge panel might have been replaced and/or serial number as the number doesn't match the model. I bought it as a 430. Then some people looked at some of the parts and thought it was a 311B. When we got into the clutch work, the parts numbers matched a 430. I love the tractor for utility work around my farm.
