(quoted from post at 22:56:35 03/09/21) I have two total, both VAO's, one from '47 and one from '49. I thought the engine on the '49 was stuck, but it turned
out to be stuck in a gear, which jammed the starter drive against the flywheel teeth when it backfired on a failed
start, so it was a relatively easy fix. The gas is coming out the opening for the air intake (I took the oilbath air
cleaners off to work on the carbs easier) It's not being forced out, but when I stop cranking the engine it dribbles
out. It doesn't affect the problem if the choke is full, half, off, anywhere. A couple folks have theorized that,
since it's not starting, the gas coming back out is what was in the manifold when I stopped cranking because it's
definitely getting into each cylinder, all the plugs are getting wet. I'm going to go back through the electrical
systems (condensers, plugs, points, coil) to check for spark and proper gaps again, then clean both float bowls and
all the jets and reset them again just in case I knocked something out of line at all. If that doesn't work, I'll
find someone with a vacuum tester who knows how to use one! The property they are on is being sold soon to
developers, and it's too muddy to pull them out with a truck at the spot they are sitting relative to the gate, so
I'm getting kind of desperate to get them moving under their own power!
