John Deere D
CASE 2470 & 2670 Flywheel Installation:
I was asked to take the lead with the ENGINE removal, of my Neighbors Case 2670. The owner was ploughing last Autumn when a PISTON appeared out the side of the Engine block!
I recently purchased an Original Case Service Manual, and have made arrangements for the local Machine Shop to turn out a Mandrel so as the components that attach to the Flywheel shall be aligned.
I have several grade 8 alignment pins so as to aid in the installation of the Flywheel.
My concerns are:
(1) The Failed Engine did not have any LOCKING devices on the Cap Screws that attach the Flywheel to the Crankshaft???
"WAS THIS A CORRECT INSTALLATION" ??
(2) Was there??? should there?? have been any liquid such as a "Loctite product" applied to the threads of the Cap screws that attach the Flywheel to the Crankshaft??
(3) The Engine that arrived that I shall be assisting in the installation of, arrived with the Flywheel Cap Screws installed in the Crankshaft / Flywheel mounting Boss....with NO locking devices.????
(4) The Flywheel has been removed.... I was not part of the removal. I can not locate any information in the SERVICE MANUAL that indicates the FLYWHEEL MUST be attached in a SPECIFIC orientation.
(5) There was NO locking devices on the CAP SCREWS that hold all CLUTCH / pressure plate components to the flywheel.??????? Item # 1 of clutch assembly...
Any owners with the above hands on...
Thanks for your assistance..
I have called a CASE DEALER, unfortunately NO ONE is able to assist me on this OLD / VINTAGE TRCATOR>
Bob...Owner Case 830 Diesel 8 speed Comfort King...Case 610....and recently a Case 930 Gasoline Engine...
My concerns are:
