connor9988
- Location
- Central Iowa
Looking for some input on what do do with my metal Case sign. I designed and cut it out in one of my college courses when I was earning my bachelors degree. The sign itself is something like 1/16" thick with a sheet metal backing riveted to it. I feel like the rivets were in error as I cant really do much with it now aside from set it on something and lean it up against the wall. I have been thinking about drilling out the rivets and replacing them with something like stainless button head type bolts/nuts. Perhaps add a spacer between the front and back plates and put a light between them... Or perhaps put a plexiglass front on it and make it into a table?
It measures 40"x20" and I cut it so that I got to also keep the eagle and Case cutouts to hang up at some point as well.
Also, if anyone has a Torch-mate CNC plasma-cutter I could crank out a for more pretty easy!
