What is this gasket??
John Saeli
This is not A11603, also not the rear pan gasket piece on an 800 or early 730 830 C-O-M. The length is correct for those, and the 2 outside
bolt holes line up, but the the center 4 holes do not line up. I'm stumped.
I would think that there may have been a miss stamping. I know you have seen them John.. There are a few that get by QUALITY CONTOL. Just saying.CM
Is it a 90 series bell housing lower seal plate gasket? those notches hold the little cork pieces,, which I am sure you already know,,
I found A150689 in the 4690 book, and A189540 in the 2090 book. In the books, both gaskets look to be the same, and neither have the notch in the corner for the cork. Otherwise they look like this one.
Could it be the early 930 with 6 speeds? Looks like the large newer blocks but like mentioned the bolt pattern is different. Just my guess
