53 DC-4 Update
chuck machinist
I have run into a few setbacks, but who hasn’t. Pastor John
thinks I’ll be putting the steering wheel on the day of the WHO
ride. No worries. I have a plan.CM
Yes it will Steve. I have good days ,and not so good days, but more good than bad. Mounting the starter switch always presents a challenge. You know what I am talking about! CM
Looking good, but remember progress is measured different ways. A good nap sometimes can be a big help. lol Seriously, I get into the most trouble when I push it and don't think things through. Sometimes it doesn't hurt to set back and watch the paint dry.
Finding a reliable starter switch is a lot harder than installing one. Where you are you will probably be fine, but here when it gets cold the starter draws too much and they burn up. I have to put a new one in every spring.
(quoted from post at 13:13:32 02/10/21) Finding a reliable starter switch is a lot harder than installing one. Where you are you will probably be fine, but here when it gets cold the starter draws too much and they burn up. I have to put a new one in every spring.
Putting new battery cables on will certainly bode well, as far as eliminating excessive current draw. Thanks Jon
