jon f mn
Got the 400 done finally! Took most of the weekend to get it done. Surprising how much there is to do after your about done. Lol. Put on a tank heater so I can use it to do chores in the winter.
Plugged it in for a couple hours before the first start to get it warm and the engine was at 180deg when it started. Should make for nice cold weather starting.
After a warm up and the re-torquing the heads I got it moved outside. First time out in a year or so.
Carries over 40lbs oil pressure, over 30 at idle warm.
I ran it at varying speeds InThe yard for an hour or so, then took it out and drive it around some. Used the brakes to load it a little and get it warmed up good. Then let it run some more. After about 2 1/2 hours I decided to hook it to the grinder to load it and see if it held. Handled it fine. Ground most of the load at a light load, but hit high gear a couple times to load it some. Seemed to handle it fine. Here is a video of it on the grinder.
Grinding feed
I never measured, but I would guess 1/2". There is a bigger
one that must be 3/4 or 1" and a smaller one that must be 1/4
or 3/8". The small one makes the feed too powdery and it
bridges in the feeders. Never tried the larger screen, I think
that might work good with ear corn for cattle.
The 1/4" screen should be used for pig feed. Corn needs to be ground that fine in order for them to completely digest the grain. Any smaller than that will cause ulcers in their gut. The bigger screens can be used for cattle feed using ear corn. You can also use the larger screens to grind alfalfa for a sow ration. The alfalfa puts enough roughage in their diet for good gut health. 1/8" screens are used for grinding chicken feed.
That's what I had always heard. I did grind the first batch for
the pigs with the small screen, but the corn wouldn't feed
through the feeders then, it would pack and bridge up. With
this screen it flows well. There are no whole or even
identifiable kernels so I think it's ok. I'll try to measure it
tomorrow to see what size it is.
(quoted from post at 12:26:50 02/02/21) That's what I had always heard. I did grind the first batch for
I had the same issues with bridging in the feeders. I would check the feeders twice a day and push the feed down where it was bridging. Pig feeders need constant attention and adjustment. What type of feeders are you using?
This one for the small pigs.
The tubes on the bottom are loose so the pigs wiggle them to
keep the feed moving there, but the fine ground feed would
bridge in the upper plastic part. This is what I use when they
are larger.
Could probably grind finer in that one.
I had the big metal feeder too. I had to check and adjust it at least twice a day. Pigs are high maintenance/labor animals. I don't miss them one bit. I do miss the good pork we put in the freezer though.
