400 fenders
400 Racine or 400 utility?CM
The Racine model fenders collected water and dirt in the lower portion , but to get to your inquiry. If you have some rough fenders that are repairable, Casecollectorsc {Steve Ching] has patch panels available. I would start with the classified section in the top Left corner of this webpage. Perusing Craigslist can be of some help. I will hunt along with you and get you hooked up.CM
If you're desperate- I have a like new pair off a VAC. These are the shorter ones. If I understand correctly, they quit making different size fenders for the VAC, but made different mounting brackets.
I am in need of repair panels for a 63 730 as the fenders rusted off at the top of the reinforcement plate. Any idea on how to contact casecollectorsc other than via a thread.
