Pulled apart the rockshaft assembly today to replace the seal, wear ring and o-ring. I was surprised that the old seal looked intact because my lift arms would drop immediately when I shut the engine off. I thought I'd find the seal in pieces. So I'm wondering if the seal can be leaking so badly and still look intact? I've had the tractor 15 years and the fluid transfer issue from torque tube to tranny started about 5 years ago but is really bad now. Also, there is a steel tube that comes out of the small oil pan under the piston and goes forward where it slides into a rubber tube. I assume this is a return line for hydraulic fluid and wondered if it's under pressure and could be leaking where the steel and rubber tubes meet?
