Case 900b wheelie bars
Mxzrip
New User
I have a case 910b that Im going to set up for stone boat pulls 6 feet to 50 feet depending on the pull. Rule are axle or rear end mounted 3 channel iron or the equivalent ridged and stationary. They must extent 4 inches behind tire with 5 x 5 pad no more then 10 from ground. Needs to support weight of tractor.
My question has anyone made them for this tractor and do you have pictures.
Does this help??---Tee
(quoted from post at 10:49:11 01/25/21) Does this help??---Tee
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto72678.jpg">
Thank you Im not sure if I can get on the axle like that because I still have all the fender and floor boards. I might need to be more on the bottom of the hitch. I do think I need to bring hitch forward like yours is it lite in the front? I have 300 lbs on front with 23.1-34 Im hoping it doesnt wheelie to easy
It is real light in the 5000 lb. class--No weights at all on it plus usually some real light guy driving--NOT me--It is on a diet right now
My new homemade transmission cover-made out of sheet metal
takes the place of this
