1964 Case 430 rockshaft seals
Pfd7a1
New User
This message is a reply to an archived post by Case430 on April 02, 2017 at 15:54:19.
The original subject was "1964 Case 430 rockshaft seals".
I have this same piston set up in my tractor. Problem i am having is finding it. If anyone come help with a part number and/or where I can get it would greatly appreciate it. Thank you.
That is going to be a fun project! Been there done that. Give a shout out to Saeli Equipment in Geneva NY. He can guide you through your seal selection 315-585-9826 Chuck Machinist
email is open
http://external_link.com/product/case-tractor-rockshaft-cylinder-piston-a36441-a36442-seal-kit/
Did that to my 611b a couple years ago. Looks to be the exact same setup, and John Saeli does indeed stock the part, and he's reasonably priced and very easy to deal with. Trick to getting it on the piston is lots of very warm slightly soapy water and even more patience. SEAL POINTS TOWARD THE FLUID! I used an automotive cylinder hone, finer the better. Good luck!
Also after the hot water and installation I used a piston ring compressor and lots of oil to get it back together. Use no sharp tools on installing the seal.
I didn't need a ring compressor, mine has a chamfer machined in. Lube both the seal and the cylinder beforehand of course, with whatever you use for hydraulic fluid. I use the handle end of an Estwing hammer to tap them in, it's Nylon.
