1170 seat OEM parts
RonSa
There are plenty of after market seat parts but I would like to find OEM parts. Any help where to find OEM parts would be appreciated.
All I actually need is 3 parts the bottom and both arm rests.
As for one who has gone through with this repair with my 441 Ron, might I suggest ladd upholstery service in the Ladd Illinois. As long as you have a solid pan part number A60461, your guy can make you something near to perfect.CM
Chuck, Thanks for the tip and the pictures. Having my old parts reupholstered would retain the original boards or plates. That fits into my goal of keeping the 1170 as original as possible. All I would loose is the imprint in the seat's bottom.
I found the 1170 seat to be very comfortable. The arm rests are just right for me.
Ladd is only a little over an hour away to the NE of me. I will try to call them soon to check them out.
The only reason I went with the pattern in the vinyl seat, was it kept my butt from sliding as opposed to a slick pattern.CM
