400/830 injectors
I have a 400 diesel that has had the injection pump replaced with one off a 830. The injectors were redone at the same time but was set for the original rotary pump. Is there a difference in the pressures of the 400 and the 830 on the pop off of the injectors? I know the 400 was 1850-2000 psi. I'm not sure what the 830 is. If there is a difference should I have the injectors set to match the pump? Thank you in advance for the advice.
