DB885 hydraulic pump access
ScottNC
No luck with this on the repair forum. There is a leak somewhere on the hydraulics suction side between the filter and the pump. Where are the pump to filter connections accessed? Once the pump (connections) are exposed can the pick-up "tube" from the filter to pump be removed for inspection?
I don't know on the 885. I believe the piping goes from the pickup back to the pump in one piece, but I'm not sure. I'd go to Messicks and look at the exploded views. There may also be views you can access at this link- https://sites.google.com/site/deerebrown
