885 water pump doughnut gasket sealer
Ken(Ark)
12-13-2020 06:31:28
Working on the neighbors 885 . We are replacing the rings and head gasket , etc .
There is a doughnut gasket between the water pump and head . We are not removing the water pump . When we put the head back on is there anything special we need to do on the water pump to head gasket / rubber doughnut . Use sealer or no sealer ? Which type ? I know some things that seem simple can be a problem .
Thanks in advance - Ken (Ark)
RGMartin
12-14-2020 04:47:29
 Re: 885 water pump doughnut gasket sealer in reply to Ken(Ark), 12-13-2020 06:31:28
new donut on a clean block and clean water pump should be OK. A thin skim of silicone on both iron surfaces is what I do and is good insurance that you don't have to do the job again.
If the tractor hasn't had a water pump yet, it would be a good time to do it.
