Company Logo Shop Now
case 931 3 point
trak
11-21-2020 15:28:44
hitch not coming up very high, doesn't seem like it goes down far enough, i turned the threads on the hitch out so it would go lower,don't know if i really gained anything there, the control lever only moves about halfway too the up position. i guess theres a rod under the tractor for the draft control, do these symptoms seem like it may be a draft control issue, ty
Adirondack case guy
11-21-2020 16:10:57
 Re: case 931 3 point in reply to trak, 11-21-2020 15:28:44
There well could be a lot of dirt built up on the cover of the DOM box and the dirt is limiting the movement of the lever. The platform floor plate is a bit of a hassle to remove but you can after the bolts that hold the seat pedestal are removed and then you can get to the top of the tranny.
Also check to see if the sensing strap is locked into one of the holes of the floorboard, and not out in la-la land.Loren
trak
11-22-2020 09:37:45
 Re: case 931 3 point in reply to Adirondack case guy, 11-21-2020 16:10:57
Thanks, highly doubt the issue is dirt or debris, this thing is Soo clean, dump truck out, tractor in.
Adirondack case guy
11-23-2020 16:21:58
 Re: case 931 3 point in reply to trak, 11-22-2020 09:37:45
It still won't hurt to pull the floorboard and check out the movement of the DOM control arm on top of the linkage housing, and as I said the "draft/position control tab with the loop on the end and pin that locks into holes in the floor plate for adjustment.
Loren
Today's Featured Article - The History of Old Abe - by Staff. The Case Eagle - Old Abe - is a well known industrial trade-mark throughout the main streets and countryside's of thousands of cities and hamlets in the United States and civilized countries the world over. King of the air, the eagle is an established symbol in American life and heritage. The Case Eagle Old Abe is far more than merely a trademark. He is a character out of history, a bird with a personality and a story all his own. The story begins in the early spring of 1861. In the wild nor ... [Read Article]
Latest Ad: Lookingfor used pipe reamer [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
