Case 970 Agriking
jab1421
11-06-2020 16:24:54
I have a Case 970 with a power shift. I purchased the tractor a few months ago so I’ve only put about 3 hours on it.
Realized I had a stuck spool valve. Took apart and cleaned all the valves. Realized precious owner threw out relief valves in hydraulic filters sometime when changing. I have replaced.
Put back together yesterday.
Now the tractor wants to backup about 10 feet or so before moving forward-this is in any gear. Anyone ever had this issue? Was not having this issue originally.
Thanks.
1370rod
11-08-2020 16:37:32
 Re: Case 970 Agriking in reply to jab1421, 11-06-2020 16:24:54
Sounds like C-2 dropping off slowly, pilot spool a little sticky maybe. Or C-2 retard to tight. Mechanical drag in the clutch pack also. Could put a gauge in the C-2 test port and watch if pressure drops quickly or slowly when depressing the clutch pedal, Rod.
