Company Logo Shop Now
1947 Case VAC
TheShoutingGrounds
10-23-2020 08:48:04
Hey all, I am new to this tractor and new to the forum.
Ive got a beautiful 1947 Case VAC that I am just beginning to learn about.
My first question is this... it seems to turn very hard while trying to start, it has excellent compression, and I noticed that the radiator fan is turning all the time. Is this normal or should the fan be controlled by a thermostat like in a modern car engine?
My second question: there is quite a bit of play in the steering. I can turn the wheel probably 1/4 turn before the long link arm on the side even moves. Is there an easy fix to this?
Third: it will pop out of reverse gear if I dont hold it down. Any thoughts?
Thanks for all you replies and help in advance.
Jal-sd
10-23-2020 13:45:26
 Re: 1947 Case VAC in reply to TheShoutingGrounds, 10-23-2020 08:48:04
If you have not noticed, your VAC probably does show a lot of oil pressure. That is normal, after warmed up, the engine is only designed to produce about 15 psi. It's engine is a low pressure high flow design. They are a tough little tractor and develop almost as much HP as their big brother the SC, but have less weight and subsequently less traction. I have both an SC & a VAC & like both of them.
tomturkey
10-23-2020 12:49:54
The gear in the transmission that controls reverse is worn down. Its correct name is the "reverse idler gear". It is worn from the previous owners forcing the gears to mesh before the corresponding gears had stopped or at least slowed down when putting the tractor in to reverse gear. There is also a brass bushing that the gear slides on, it could be worn out also. It is an easy fix even for a rookie. But you must find a replacement reverse idler gear and or bushing from a salvage yard or parts tractor. You will be able to hold it in reverse for a while, but sooner or later you will not be able to use reverse as it just won't stay in gear. A contributing factor to your problem could be that it is low or empty of gear oil from a leaky axle seal or transmission gasket or seal. So check that out. Welcome to the forum. Welcome to the world of J.I.Case tractors. gobble
Joe (Wa)
10-23-2020 12:43:58
The likely reason for not staying in gear is wear on lock mesh balls, weak lock mesh springs and/or worn rail lock mesh detent in the shift rail. In an old tractor it can be a combination of all three. Replace the balls, check or replace springs, dress up the rail detent.
Joe
Joe (Wa)
10-23-2020 14:46:06
 Re: 1947 Case VAC in reply to Joe (Wa), 10-23-2020 12:43:58
I forgot to mention a bent reverse fork can cause the gears to not fully engage and jump back out under load. I haven't run into the reverse idler gear problem that tomturkey described but can well imagine that happening.
The link below is an on-line pdf VA operators manual for VA series tractors built prior to 1949.
Joe
Bob Bancroft
10-23-2020 09:15:46
I found a washer bent on the bottom of the steering wheel shaft, after pulling it out of the steering gear. Fixing that helped a lot.
TractorTucker
10-23-2020 09:01:35
The radiator fan will turn all the time because it is driven by a belt off of the crankshaft. I would suggest getting a service manual and owners manual for the tractor to help you keep it running and fix any problems that might show up. Your tractor should have a thermostat in one of the radiator hoses. It might have been removed at some point in the past, if you have problems getting the tractor up to operating temperature, I would suggest checking and possibly replacing the thermostat.
Link to online parts catalog for Case VAC
https://www.mycnhistore.com/us/en/caseih/na/tractors/agricultural/legacy/case-titan-tractors/cn/AEE26496-EFBE-E111-9FCE-005056875BD6
Bob Bancroft
10-23-2020 09:17:39
 Re: 1947 Case VAC in reply to TractorTucker, 10-23-2020 09:01:35
I got good gauges and a 180 degree thermostat from John Saeli for mine.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
Latest Ad: 560 factory lp has Schwartz wide front new seat all gauges work fast hitch 14.9 38 tires has power steering leak on return side lights work ta works as it should 2 sets rear wheel weights possible trade on other tractors 340 farmall john deeres molines can text pics [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
