jon f mn
There is a disturbance in the force! I didn't know the 1818 was wider than the 1816. She's JUST a smidge too wide.
She would just go through without the door stops. Guess there is some door modification on the list of things to do now.
(quoted from post at 15:23:26 10/16/20) There is a disturbance in the force! I didn't know the 1818 was wider than the 1816. She's JUST a smidge too wide.
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto59582.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto59583.jpg">
You know if you give it some time, you might accidentally hit the frame too hard and then you will have the clearance you need! just saying! CM
Just to get started you need a reciprocating saw and a 8 inch long demo blade or a chain saw and then you are in.
