Ken Christopherson
Hello all. Been a while since I have posted, but I am always reading. I'll cut right to the chase on this. Many of you have seen the '41 SC center exhaust I have. I did an engine teardown and rebuild about ten years ago, but never touched the transmission (I should have). I am looking at now tearing it down and doing a complete overhaul on the transmission. Has anyone done this recently on the SC? Any bearings or seals that are no longer available? I think that the left brake pinion will need a speedy-sleeve installed (or pinion shaft replaced) as I resealed it a few years ago but never could get it to quit leaking. The old girl is growling pretty good, so I would imagine that it is a combination between loose chains and worn bearings. It also pops out of 2nd gear while going down a steep hill. My guess would be a worn gear.
I'll be chronicling the entire process on my YouTube channel, so that future generations can reference and enjoy the process for their own projects. Not a whole lot out there for Case SC teardown or repair videos (other than mine).
Look forward to your responses. I know Don Livingston and John Saeli are great sources for parts. Picture is just for fun. Was getting some brush cleared and smoothing out some dirt before planting a little grass. Also included a video link below.
Case SC Doing Yard Work
