History on this, I recently bought this not running. It had sat for ~2 years supposedly and drove to where it was. Engine turns over but it seemed like it sounded like 1 or 2 cylinders were weak when turning over. Got it home and found 3 bent push-rods and 2 stuck valves. Replaced the push-rods, freed the valves and now 3 seem ok but 1 seems to be popping back through the intake. I re-adjusted the valves also to .014" on all per the manual. I am thinking next step is pull the head. I noticed there are no timing dots on the idler gear which someone replaced at some point. Thinking the next step is pull the head. 1st picture at top dc by timing mark on crank, 2nd is 8 before dc
Any suggestions greatly appreciated
