Needing DC Case engine
Farmallb I don't know where your located but i have a dc i still use some. Would willing to sell. Richard
Where are you located? I might be able to fix you up after harvest, I have a parts DC that appears to have a good block.
Mike
Assuming their operable, Do you have the services of fastenal in your area? IF so, you would have to put them on a pallet and they would pick them up. IF there is a fastenal co in your area, could you ask them what it would take to ship them to Chelsea Okla? My Ph# is 918 934 5488. Im retired so you could call anytime in the afternoon. Do either have the flywheel on them? Im putting a engine into my 34 CC Case, and at 74, I want to be able to start it by battery I still farm with it. Thanks.
If the CC did not originally have a starter, it won't do any good to get an engine from a DC with a starter. There won't be a bulge in the CC bellhousing for the nose of the starter to fit into.
The CC is my grandads tractor, first and only. I use it for heavy work, plowing and discing, and its great on the belt on either the hammermill or buzz saw. I like to grind up a bale of alfalfa in the spring just to use the hammermill, Wetmore, and use the ground hay for plant fertilizetr in my garden. I buz up a pk load or 2 for my daughter in the fall. The CC, doe to having the DC engine in it, was a stron, stready puller, a bit more than my 48 H Farmall. I farm around 6 acres here in Okla. u can get in 2 crops on the same ground here. Where I used to live a neighbor put in wheat and corn. I put in corn and then haygrazer, and get a cutting off of it then plow it under
I thought I had replied to you, but perhaps I didnt. What shape are the engines in? loose or stuck? I would give some money for your effort in getting them ready to be shipped, depending on their condition? Do you have a Fastenal store in your area? If so, they would ship them. Id pay the freight bill. My Ph# is 918 934 5488
Sorry, I've been off the list for a couple of days. One is on a skid, the other is still in the tractor. I can check with fastnal to see what the shipping would be and let you know.
