1965 Case 930
crankin12864
New User
I have installed a new carb, pertronix electronic ignition, new coil, new plugs and wires, adjusted valves to spec, adjusted timing to spec. Tractor ran great for a week, just like a new one. Today it runs as if it isn't running on all cylinders. I have double checked everything and can't find anything wrong. Any thoughts?
The first thing to look at is the work you've just completed, that's usually where an issue will be. Next fuel. Gasoline in a tin tank that's not full will develope tremendous condensation, particularly this time of year and early spring with the cool evenings and warmer days. My 2 bits. Larry
