Company Logo Shop Now
needing part for VAC
Farmallb
09-26-2020 09:27:05
Anyone have the cover for the oil filter for a 51 VAC to sell?
rfdmn
09-27-2020 07:35:14
 Re: needing part for VAC in reply to Farmallb, 09-26-2020 09:27:05
I also have a vac without a filter. I wonder if may be a combine engine installed in the tractor?
Joe (Wa)
09-26-2020 21:03:59
no cover on the VA series tractor oil filter like this VAI.
Go to the link there are dozens of early 1950's VAC pics, no cover on any oil filter.
Joe
J Hamilton
09-27-2020 05:49:32
 Re: needing part for VAC in reply to Joe (Wa), 09-26-2020 21:03:59
Do you know if an oil filter was an option on these tractors? We have a 49 VAC that doesn't have an oil filter, just a block off plate where it would mount to the block.
Case Nutty 1660
09-27-2020 10:43:45
 Re: needing part for VAC in reply to J Hamilton, 09-27-2020 05:49:32
Oil filter was a option, at least early on,, if you do install a plate you have to make the gasket so it allows oil to flow from one port across the plate to the other cnt
Joe (Wa)
09-27-2020 12:58:21
 Re: needing part for VAC in reply to Case Nutty 1660, 09-27-2020 10:43:45
Tom, you are thinking of the in-line filter systems, VA has a by-pass filter system from the oil galley through filter and back to the sump.
Joe
c.amick
09-26-2020 18:30:49
Never seen a cover for one. The spin on oil filter was always exposed.
Farmallb
09-26-2020 20:19:23
 Re: needing part for VAC in reply to c.amick, 09-26-2020 18:30:49
Well, I just assumed it had one,which It didnt when I got it. I can see where a spin on filter could be right also. But, I dont know.
kenbob
09-29-2020 10:56:55
 Re: needing part for VAC in reply to Farmallb, 09-26-2020 20:19:23
If you decide you have a spin on, there should be a tube sticking up from a hole in the filter base. It goes missing quite often as newbies (like me) unscrew the filter and don't see that tube stuck in the bottom. You can fabricated one easy enough out of copper tubing. If you put on a spin on without it, you won't have much oil pressure.
kenbob
09-29-2020 10:58:42
 Re: needing part for VAC in reply to kenbob, 09-29-2020 10:56:55
Sometimes called mason jar filter as the threads look a bit like a mason jar.
old
09-26-2020 13:31:50
I have 2 1946 VAC parts tractors so I may have one laying around. E-Mail is open
Latest Ad: 1968 John Deere 3020 orchard diesel, needs full restoration. Asking 8500 or best offer. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
