Mission Creek
Last winter I was blading snow and pump starting grinding/pinging noises, lost 3 point as well. Tool pump off and after taking apart it seemed a little sloppy. Replaced pump/flushed hydraulics in spring and while baling hay the pump started to make the same noise and baler gate hydraulics were extremely choppy and then failed all together. Took the pump off and it still seems tight. Now I’m questioning if there’s something else causing the hydraulics to fail and making that noise. It sure sounds like it’s coming from the pump and what else would make the hydraulics choppy? I change filters after the flush and use mastertran ultraction. Any help would be appreciated.
