Did CASE make Truck Farm Equipment?
K-Mo
In the past, most major manufacturers built equipment for growing vegetables. Most were offset like the Farmall Cubs and As. Allis had the "G". CASEIH and JD still had offsets in the 90s. I don't recall any CASE equipment.
Tractor data shows a vas (high clearance offset controls) if that is what you consider truck farm equipment.
CASE/DB built the 1394 4x4 "Mudder" in the 80s for specialty vegetable farming. Also high clearance DBs from the 1960s through the end in 88.
Case also built the VAS, which was an offset, high clearance version of the VAC. It was designed to compete with the Farmall A. Got one with a parts tractor to restore, plus cultivators. But I have too many projects in front of it.
