Case 730 reverse speed
chas036
Can someone give an idea of the reverse speed for the low range reverse on a Case 730 Comfort King? I looking for a tractor with a reverse speed less then 2 mph so I can use it on a snowblower.
Tractordata.com730Casetractor ..... type that exactly like you see it at google. it lists all forward and reverse gears in the Nebraska Test CM
Reverse low will be plenty slow, high will be plenty fast. Neither is great. But you won't have much problems being slow enough. Dad most always used our 730 on the snow blower.
