1958 case 400b parts
Hello everyone I'm looking for a few parts for my 400b hopefully someone can help me out I'm looking for a radiator new or used doesn't matter to me and the hand throttle lever from the dash as well as the linkages from that to the smaller linkages that run down the right side of the motor. Thanks guys
Adam
Can't help w/ the linkage, but check this out:
http://external_link.com/product/case-200-300-630-tractor-throttle-case-o-matic-handle/
I should have done a little research. The radiator listed at that Maine link is p/n G45180 it is for a 1959 model 400B. The 1958 model 400B radiator p/n G45139 is shorter.
If your grill cap has a small square cover over the radiator filler neck/cap it is 1958, no cover there just a round hole for the filler neck/cap to stick up through is 1959.
Having said that either radiator may possibly be fitted in there, something I don't know for sure.
Joe
Well yes joe mine I believe is the radiator that I'd shorter my radiator cover does have the square hole for the cover to be put in but I will check it out maybe it can be fitted in like you said thanks
