I am trying to find the selling value of a 64 Case 530 CK on my property that I salvaged.
Hydraulics work after replacing the pump and most of the hoses.
Cleaned out fuel tank, hydraulic tanks and oil pan.
Fuel, oil, and hydraulic filters, oils and fluids have been replaced.
There seem to be a lot of repair welds on different areas.
It runs and drives but shuttle shift keeps popping out of forward gear.
All hydraulic rams leak especially the large crowd ram.
Tires are poor rear one bald.
Wheel Breaks are worn out and have oil or grease on them and don’t work.
The oil pressure and amp are replaced and the only gauges that work
Engine blows a gases and coolant out the radiator cap, you can’t have thermostat installed or it will push coolant into oil pan.
