Re: '53 SC: what plug to get to plug off unused bottom hydraulic
kycase1
08-17-2020 06:02:06
I had the same problem with the leak when I restored my SC. Mine leaked at point 1 (picture)were it swivels. I marked the fitting were it was at the position I wanted and then had it Tig welded all the way around. You should be able to find a plug to fit at point 2 (picture). And yes keep the ball and spring it is part of the hydraulic system.
Third Party Image
DennisT
08-17-2020 07:02:09
 Re: '53 SC: what plug to get to plug off unused bottom hydraulic in reply to kycase1, 08-17-2020 06:02:06
Thank you KYCase1. Yours is the most important reply to date. I wondered about the spring and ball; now I'll do what ever it takes to retain it. From your comment, it appears there may be little value in finding a new, "plug," to fit directly into the tractor's housing because the plug will not accommodate the spring/ball required. I suspect the, "point 2," you so artfully inserted in the photo, will accept a different thread size more easily located. Guess I'll look for a fellow to do the welding.....
DennisT
08-17-2020 07:16:03
 Re: '53 SC: what plug to get to plug off unused bottom hydraulic in reply to DennisT, 08-17-2020 07:02:09
KYCase1: Just noticed something: I see in your improved photo, what you did. However, on my fitting(s), I also have a leak between points 1 and 2. It's where the previous owner tied the wire around the joint. So I would weld around that also? Which makes two circular welds.....
kycase1
08-17-2020 16:34:38
 Re: '53 SC: what plug to get to plug off unused bottom hydraulic in reply to DennisT, 08-17-2020 07:16:03
Yes you can weld that too.
