Removed the old Wagner loader from my '53 SC. Now lower pair of hydraulic ports on the pump housing are not in use. Tried to adapt what was left after removing old hoses and make these 2 ports, "plugged off." Can't get old fittings to stop leaking. Threaded piece that screws into cast housing with it's copper washer is not a problem. It's the junk plumbed outside of that. What/where can I get a fitting that will screw into pump housing and just act like a plug? I tried taking it to hydraulic shop and they could not find anything to work. Tonight I went to neighbor's machine shop and he identified the threads as 1"x14thd. Old fitting contains spring and ball. Can't see why that's needed now, but......?
Thoughts would be appreciated. I can take photos tomorrow if needed.
Dennis in E WA state
