Wicksfield
I have an injector with a slight leak at the "T" fitting that screws into the top side of the injector. I've heard and after looking at it, I don't believe the fitting can be removed due to interference with the head. Is it possible to loosen the injector mounting stud nuts a few turns to pull the injector away from the head allowing the T fitting to be unscrewed? Is there a special tool required or the need for a new injector seal or something or another? Or, just tighten the injector back down after sealing the T fitting?
Thanks for your response.
