Case 1470 Master cylinder
JWDozer
No breaks... can't find a new master cylinder from case, napa or local classic tractor guy. Old post talked about napa matching... my local napa can't do it. Does anyone have a matching/cross reference part number that would work to get something like an aftermarket napa or a clark forklift master cylinder?
Thank you.
used this number from old master cylinder found a replacment on internet wagner lockheed pe-14022 went to off brand number b 239 bolts up same
You could look around here. Make sure the piston bore size is same.
https://www.speedwaymotors.com/shop/street-rod-master-cylinders~65678-1-225-3-477-30478
For what its worth our local repair shop used a GMC master cylinder on our 4494 when that failed and new was NLA from Case - about 3 years ago.
One more reason we ditched the 4494.
