Hello all, I had posted before and received not only good info but quick responses as well from members here. I was hoping to get some advice on my leaking forward reverse transmission. I picked up my old backhoe in the fall last year after getting it functional I started working my way through the leaks. Ive done 8 cylinder rebuilds a few hoses and some other basic maintenance and it is running the best it has been yet. However now its started to leak from the power shuttle. Before I had bought it apparently the torque converter had been changed,bearing in mind it had sat for the previous 10-12 years before I got it. At some point either while diagnosing or changing the torque converter they drilled holes in the bottom of the torque converter housing not sure why, but this is where the leak dribbles out and only starts when it warms up. As Im just starting an addition on my house I kind of need to be using the machine now. Im figuring ya that it will have to come out at some point but would like to keep it going for now.
Any ideas , things to do to possibly narrow down the problem or anything that can be done to slow the leak to keep it usable now I wouldnt say its bad but I cant disregard it. Also where I could get the rebuild kit and parts for it online Im in Canada. Thanks a lot in advance.
