1370rod, or anyone ; 930 seat
LJKCK
Rod, I remember a while back you had a post on putting an aftermarket seat and base on a 930, I believe it was K&M. I was wondering if the seat comes with the base bracket for the 930,1030 or separate. I assume you got it from tractorseats.com since that is the only place I can find with it listed for the 30 series. I'm getting tired of the crappy rubber springs not holding up so I figured I'd go with something better. Any other ideas I'm open to as well.
John I like it, any reviews on how it "rides"? I do like the Made in the USA. If I get time I will probably give you guys a call in the next day or two, I believe you are 2 hrs ahead of us too.
Larry: We had 2 customers install them on 830 CK's. On the 730 830 CK's, the seat hangs off the tool box frame. On the 930 1030, the seat bolts to the floor, and the floor is supported. So if one of these units are to be installed on a 730 830, the floor needs to be reinforced underneath, which is what both our customers did for their 830's.
I installed one on an 830CK works great I made a new seat mount plate for mine so it slides back farther. Very comfortable and soft riding
