Company Logo Shop Now
Re: 1991 Case 1140 Motor Rebuild
Brods
08-09-2020 03:31:03
Pinheads2 hopefully you are still getting notifications from this thread. Can you do me a huge favor and look at your frame where it mounts to the front of the engine and see if the flat bar tabs are welded to the side rails? I can't post links or pictures of the part in question due to the forum's antispam rules. If you do an image search on case part "1991780C1 main frame" that will show the part in question.
While fixing this part for my neighbor it was obvious someone had attempted a repair, probably while it was still on the tractor. While grinding that mess off, there were no tell tale signs of the factory welding these tabs or the flat bar to the side rails except over the front axle mounting plates. If they were designed to flex, then I don't want to weld them solid and risk damaging the engine casting. They definitely were not welded on the bottom side. If you could check the top side and post up what you find that would be very helpful!
Thanks
Copyright © 1997-2020 Yesterday's Tractor Co.
