Company Logo Shop Now
Case 2290 Powershift issue? Engine Stalls
Anselmostone
08-08-2020 21:19:47
our 2290 was baleing and I stepped on the clutch to powershift down from 2nd gear powershift to first, and then the engine stalled out. The tractor is in neutral now, but when we go to start the engine it just stalls right away after a few seconds.
mEl
08-09-2020 08:21:24
 Re: Case 2290 Powershift issue? Engine Stalls in reply to Anselmostone, 08-08-2020 21:19:47
Angel, try starting it and quickly shifting into second PS position, If it does not stall there then I suspect C-3 pilot spool stuck. As the other poster said, the reason this happens is lack of maintenance in trans oil and filter changes.
kycase1
08-09-2020 05:59:21
My Dad had a 2290 several years ago that did the same thing. It was the C1 spool in the valve body that was sticking. We would clean it and it would run good for a wile and it would stick again. He was trying to get through hay season before working on it but he did not make it. It took out the torque limiter and several other parts the last time it stuck. After rebuilding the torque limiter and some of the clutches in the transmission $$$$ we took off the valve body and cleaned it inside and out. We determined that the root cause was dirty oil. After the repairs he ran the tractor for several more years with on problems. It is a must to keep the oil clean in the power shift trans mission.
Anselmostone
08-09-2020 06:48:47
 Re: Case 2290 Powershift issue? Engine Stalls in reply to kycase1, 08-09-2020 05:59:21
Wow, thank you so much. Me and my dad really appreciate your post!
Jeremy McNary
08-08-2020 23:06:13
one of the spools in the control valve is likely stuck, search the archives for more info on how to free them up or if you have a service manual look through the section on the powershift valve.
Today's Featured Article - Two-Brush Generators - by Chris Pratt. Whether for product liability or because the aftermarket parts and labor business is lucrative, this concept is disturbingly prevalent. Fortunately when you step into your shop and make that jump 50 years back in time to work with your old tractor, this concept goes out the window. Even so, when it comes to the charging system, people quickly revert to this idea and start replacing the major components one at a time until it works. The reason you don't find any decals in your replacement set wit ... [Read Article]
Latest Ad: Needing good 70 series fenders. No rust or dents preferred. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
