Company Logo (800) 853-2651 Shop Now
case 430 hyd
jim on van isle
08-08-2020 08:43:50
Is there hydraulic ports on this tractor that I can plumb some lines into to get constant flow so that I can run the hydraulics of our bale wrapper? Thanks. Jim S
bradley martin
08-08-2020 12:36:07
 Re: case 430 hyd in reply to jim on van isle, 08-08-2020 08:43:50
You can for a very short period of time before the pump or valve or both burn out. Small reservoir heats up real quick! A lesson I learned the hard way attempting to convey a wagonload of beans.
mEl
08-08-2020 10:04:32
Not in its present configuration, it may be possible to to get a top hydraulic valve cover off a DOM tractor that fed live hydraulics to the DOM valve and use that as a constant flow feed but it will have to be hooked up to a sump return in open center configuration so flow is not interrupted when the machine is unhooked. If the flow is blocked off the pump will be forced to pump against system pressure and pump damage will occour quickly.
Tgrasher
08-08-2020 11:53:07
 Re: case 430 hyd in reply to mEl, 08-08-2020 10:04:32
What happens when the remote lever stays in a flow position and both hoses are used. Can one power a hydraulic auger?
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea ... [Read Article]
Latest Ad: John Deere DUBUQUE Parts for sale- 24 inch power adjust rims, 3 point hitch parts, Utility Rockshaft, Utility Anchor Yoke, 40 Standard ring and pinion, various 40 transmission gears. Other DUBUQUE parts available. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
