Case o matic clutch pedal
Eaglehitch
New User
My clutch pedal when depressed does not return with Out manually pulling with hands. It just started to do this The return spring is good seems like something needs grease but dont see any locations for grease. 830. Case o matic with square fenders.
I would start by pulling the pin on the linkage to see if the
problem is with the peddle or valve. Could be either.
