885 battery discharges
indiana george
08-03-2020 10:47:44
I have a david brown 885 diesel ,and the battery discharges when the tractor is not running.I have checked all the wiring for a short but can't find anything.Any help will be appreciated
LDCravey
08-08-2020 14:52:49
 Re: 885 battery discharges in reply to indiana george, 08-03-2020 10:47:44
I have a Case 380CK, which is very similar to the 885. I have the complete wiring diagrams for the Case if you need them.
If the instrument cluster was removed, there is good chance that a wire might have been accidentally relocated to a wrong terminal.
Also, the original ignition switch gets a lot of dust/dirt/oils in it over a long period of time, and this could result in current leaking from one terminal to the next inside the ignition switch (or any of the switches.)
Best way to troubleshoot is using an Ammeter inserted in the battery lead (but not while cranking, since that would destroy the Ammeter). Ammeters are always inserted in line (in series) with the wiring, never across (parallel) anything.
In general, if you have a large current draw (more than 1 amp), then alternator, voltage regulator, starter solenoid, lights might be the cause. If current draw is less than 1 amp, then small indicator lamps, leaky switches (caused by dust, dirt, oil), voltage stabilizer, gauges, etc, could be the cause. Make sure that the ignition switch is in the OFF position, not the ACC (accessory) position.
With the switch off, start disconnecting wires from the ignition switch until the current goes to zero. Whichever wire is causing the current drain, trace the wiring from that circuit.
Let me know if you need a schematic.
indiana george
08-08-2020 15:13:07
 Re: 885 battery discharges in reply to LDCravey, 08-08-2020 14:52:49
Thanks for the offer to send me the wiring diagram ,but I do have the diagram,also thanks for the tips
derwen1959
08-04-2020 07:17:05
I had same problem with JD 2040 and was caused by Starter solenoid...
RGMartin
08-03-2020 12:11:03
The OEM Lucas alternator on them will do that. Disconnect the alternator for a while and see if the battery goes dead.
indiana george
08-03-2020 16:00:46
 Re: 885 battery discharges in reply to RGMartin, 08-03-2020 12:11:03
RG I have a new alternator ,but not a lucas one
rvirgil_KS
08-04-2020 06:49:47
 Re: 885 battery discharges in reply to indiana george, 08-03-2020 16:00:46
What alternator do you have and how is it wired?
indiana george
08-04-2020 11:13:58
 Re: 885 battery discharges in reply to rvirgil_KS, 08-04-2020 06:49:47
The only one I could find is a Wilson, and I just plug the wiring into it ,I did not have to wire anything,just like the old one,
old
08-03-2020 11:58:34
Generator or alternator?? If a gen good chance the Voltage regulator is bad.
